| Sounds louder on the drivers side from underneath the car, but its hard to tell for sure, could just be the back of the motor as well .....PCV's and silicone hoses were new last fall ... so maybe 500 miles on them ... but i could definately check Also i did the smoke test as well ... like use some burning incense or whatever while doing the boost leak test and nothing was visible. TPS is in spec .... timing is 15 degrees ... although im not sure if thats correct since the idle is higher than normal .... i took the IACV and air regulator off the plenum and tried cleaning up the connectors as there was some corrosion in there ... everything ohmed to spec except for the main plug on the IACV ... its supposed to be 10ohms and it ohmed in at 14 ... And the idle does not change with the adjustment of the screw .... do you think that could be the issue, with such a small, if any leak at all ? Thanks again for any help
